hello all! i am new to the site. i am looking for information on building a fuel injected 514 big block to go in my 94f350. i have it set up with dual transfercases 2.5 ton rockwells and 18 inches of lift. i use it for grudge pulling and also mudbogging. i built it all myself and have never built an engine before and want to build a big stroker motor to put out around 600horse and 600ftlbs of torque. FORDS ALL THE WAY!!!
Well it can't be said you started off small. You will need to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the choices. There are several that will apply to your project. You might try this one and go from there: https://www.ford-trucks.com/forums/forum47/
