Rough Idle
Old Feb 4, 2007 | 03:44 PM
Weedeater's Avatar
Weedeater
Question Rough Idle
MY TRUCK HAS A ROUGH AND LOW "525RPM" IDLE WHEN HOT ALSO SMELLS BAD. FORD SAID # 7 INJECTOR IS BAD AND THE REST ARE WEAK. DOES ANYONE ELSE HAVE A CHEAPER IDEA?
Old Feb 4, 2007 | 03:47 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
Lose the caps...............check the wire harness plugged in through the valve covers and look for anything burnt, check all four connectors. Start from thier, search for missing pins and/or what smells like burnt plastic/electrical
