engine problems
Old Feb 4, 2007 | 03:43 PM
roverf150's Avatar
roverf150
engine problems
took valve cover off 1993 6cyl 4.9l and found #6 rockers badly fouled. all others look okay. engine runs badly looking to fix myself.
Old Feb 4, 2007 | 06:09 PM
wormshoe's Avatar
wormshoe
What is your engine doing? Smoking? Missing? Hard to start? Pinging? No power?
It would help to know a little more than what you have said so far.
Old Feb 4, 2007 | 08:19 PM
roverf150's Avatar
roverf150
it's smoking grey smoke, idles rough, shakes when accelerating, no ping, starts up good.
Old Feb 4, 2007 | 10:07 PM
pfogle's Avatar
pfogle
Does the smoke have a sweet smell like hot anti-freeze? What does the oil look like? You said the rockers are fouled up, describe what you mean.
Old Feb 5, 2007 | 06:57 PM
roverf150's Avatar
roverf150
we found after taking off the valve cover that two rods (2, & 6) were not seated in their position on the arm, they had moved out from under their arm! we did have some problems from bad fuel which caused a lot of misfire. we loosened the bolt and returned the rods after inspection for bent or damaged, they weren't, to their place. we put everything back,and she started and ran fine! so far after 20 miles she's okay. we have 265,000 mi. on this engine and the bad fuel issue was very unfortunate for it.
