Ext balanced q's 302
Old Feb 4, 2007 | 10:10 AM
scottie2hottie's Avatar
scottie2hottie
Question Ext balanced q's 302
I have an 87 302, it used to be in a 4spd truck, i am putting it in an automatic truck, am i gonna have issues with the engine balancing if I switch from the heavy flywheel over to a flexplate? I am using the correct flexplate for an 87 302 w/ automatic....thanks for input.
Old Feb 4, 2007 | 10:31 AM
baddad457's Avatar
baddad457
No, the imbalance factor is the same for both manual and automatic. Make sure to remove the pilot bearing or bushing from the rear of the crank. Otherwise the torque converter won't seat in the rear of the crank.
Old Feb 4, 2007 | 03:59 PM
HemiEater's Avatar
HemiEater
what year flexplate?
Old Feb 5, 2007 | 01:49 PM
scottie2hottie
I bought the flexplate new- for an 87 f250 302 c6. Autozone part# FRA-231. And I have starters off either a windsor/auto(diff flexplate number tho) and the 302 4 spd, will either work?
Old Feb 5, 2007 | 03:03 PM
HemiEater's Avatar
HemiEater
the auto will
