Found Fuel Leak
Old Feb 3, 2007 | 06:10 PM
ramrod7373's Avatar
ramrod7373
Found Fuel Leak
I found my fuel leak. It is off the back of the pump (behind fuel filter housing) at the y where the lines are coming out of the pump. Is this something I can do? I am mechanically inclined, if all I have to do is take out the nut out the back of the pump and put new o-ring in. Is it that simple or what am I looking at? Also I found I am leaking coolant out of the temp sensor. I will get a new one of those and put in(hopefully not a big deal).....
Old Feb 3, 2007 | 08:15 PM
plowhand's Avatar
plowhand
Playing in the Dirt
If it's leaking from the banjo bolt on the rear of the fuel pump you will need two "Fuel Line Banjo Outlet Seals" (Ford) F4TZ-9A375-A. It's not too hard just a PITA.
Old Feb 3, 2007 | 08:50 PM
14psd's Avatar
14psd
Just make sure your coolant leak is the sensor and not the thermostat neck. Those are prone to leaking. I had to replace mine. Even the new one would not seal, I had to tap it lightly on the floor of the garage to get it flat enough that the rubber o-ring would seal properly. Instead of replacing the sensor put an actual gauge on your truck. Just a thought.
