Rocker Arm Studs
Old Feb 3, 2007 | 03:17 PM
CommrclDiver's Avatar
CommrclDiver
Rocker Arm Studs
I was wondering if the rocker arm studs in a 1971 302 were pressed or threaded? If they are pressed is there any way to get them out while I am on the road (no shop or special tools), or do I have to take it to a shop to have it done? Oh and im having trouble adjusting my rockers in the first place. I can get them to sound good for the low and mid RPM range but in the higher RPM ranges they clatter. Please help, Thank you.
Old Feb 3, 2007 | 03:29 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
This is best asked in the engine forum that relates to the 302 as it is Engine specific.
302's changed over the years and it has nothing to do with the 67-72 truck.
I would say press in as there is no listing of a torque spec here for studs.
http://members.tripod.com/torquespecs/hi_po_ford.htm
Old Feb 3, 2007 | 03:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
302 Rocker Studs 1971/72
C9OZ-6A527-A Stud, Rocker Arm .. 5/16" - 24 x 2 3/4" .3717" Diameter
..................B............................... .......... .006" O/S
..................C............................... .......... .010" O/S
..................D............................... .......... .010" O/S
Only one end has thread size listed. They press in.
Old Feb 4, 2007 | 08:56 AM
Dave Severson's Avatar
Dave Severson
Several compainies and most of the tool trucks sell rocker stud pullers. I've tried the oversize, they do work fairly well. The best cure I've found is to remove the heads, take them to a machine shop and have the studs removed, bosses milled, and the holes bored and tapped for aftermarket screw in studs. Then, they stay in place,.,,,,
