Sponsored by: Real Truck
Central Ground Location
Old Feb 3, 2007 | 01:03 PM
UAHCIVIL's Avatar
UAHCIVIL
I am installing a PIE Aux adaptor in my 05 F250, need help locating the central ground location to tie my gounds into. Any help? I could tie into the ground off the radio. I know which wire that is.
Old Feb 3, 2007 | 01:47 PM
ReAX's Avatar
ReAX
The battery is probably the central ground, but the body is grounded so you can tie in anywhere. If they mentioned it in the instructions, they most likely mean the radio's ground to the body.
Old Feb 3, 2007 | 01:49 PM
MisterCMK's Avatar
MisterCMK
Use a good solid connection to the body
Old Feb 3, 2007 | 06:57 PM
UAHCIVIL's Avatar
UAHCIVIL
Thanks to the both of you. After going back outside I found a grounding point behind the fuse panel. I was able to make a soild tie there. Just didn't want so many splices behind the radio. Hooked everything up and it worked first try. Thanks again
