99 E150, 4.2
Old Feb 3, 2007 | 12:53 PM
madcapper's Avatar
madcapper
99 E150, 4.2
I have a HVAC blower relay. I think mine is gone. Where is that thing located so I can switch it out. This relay has a metal tab on it like it screws to the frame or someplace else. Anybody Know where its located..........
Old Feb 3, 2007 | 03:21 PM
Ultramagdan's Avatar
Ultramagdan
Yes, it should be located next to the blower motor. There is a blower motor housing tub that runs from the motor to the firewall and the switch is right next to it.
Disassembly
Remove the blower motor (19805).
Remove the blower motor housing tube (19A786).
Remove the four screws.
Remove the retaining clip.
Remove the blower motor.
Remove the heater blower motor switch resistor (18591) .
Remove the two screws.
Remove the heater blower motor switch resistor.
Old Feb 3, 2007 | 03:27 PM
madcapper's Avatar
madcapper
Wow, I am not impressed with this. his will obviously take a while. I presume this is all done from under the hood. Correct.
Old Feb 4, 2007 | 09:11 AM
madcapper's Avatar
madcapper
So I am reading this as it is inside where the Blower Motor is........correct
Old Feb 4, 2007 | 12:39 PM
Ultramagdan
It is in the engine compartment.
Here are the directions if you were to replace the motor.
Blower Motor
Removal
Remove the battery (10655).
Remove the battery tray.
Remove the screws.
NOTE: This step must be performed if the vehicle is equipped with an A/C system.
Move the suction accumulator/drier (19C836).
Remove the three screws.
Move the suction accumulator/drier.
Disconnect the electrical hardshell connector.
Remove four screws.
NOTE: To ease removal, align the flat spot on the blower motor mounting plate with the accumulator.
