engine dyno
Old Feb 3, 2007 | 09:54 AM
Ford150/428/dud's Avatar
Ford150/428/dud
engine dyno
Could someone calculate roughly the horse power and torquefor my 1970s 428 that im building.
Cam/lifters<TABLE border=1><TBODY><TR><TD>Grind Number:</TD><TD>266 H10</TD></TR><TR><TD>Operating Range:</TD><TD>1400-4800 RPM</TD></TR><TR><TD>Duration Advertised:</TD><TD>266° Intake / 266° Exhaust</TD></TR><TR><TD>Duration @ .050'' Lift:</TD><TD>210° Intake / 210° Exhaust</TD></TR><TR><TD>Valve Lift w/1.76 Rockers:</TD><TD>.516'' Intake / .516'' Exhaust</TD></TR><TR><TD>Lobe Separation Angle:</TD><TD>110°</TD></TR><TR><TD>Max Lift Angle:</TD><TD>105° ATDC Intake / 115° BTDC Exhaust</TD></TR><TR><TD>Open/Close @.050'' Cam Lift:</TD><TD>Intake - 0° BTDC (opens) / 30° ABDC (closes)
Exhaust - 40° BBDC (opens) / (10°) BTDC (closes)</TD></TR></TBODY></TABLE>
factory springs/valves
Rotating assembly is stock
factory 4bbl intake/reman holley 600 carb
Hooker headers, dual exhaust
fel-pro head gaskets
is that about all i need.
thanks
Old Feb 3, 2007 | 11:51 AM
Torque1st's Avatar
Torque1st
Posting Legend
To run a decent dyno program you need actual seat to seat cam timing figures.
Old Feb 3, 2007 | 01:06 PM
Ford150/428/dud
Sorry for dumb question but what exactly is seat to seat timing figures. If not how much would it throw off the dyno of would it not work at all.
Old Feb 3, 2007 | 03:57 PM
rusty70f100's Avatar
rusty70f100
I should be able to do this...
Here are the seat-to-seat timing numbers for that cam. They can be calculated with the info provided.
IVO:28
IVC:58
EVO:68
EVC:18
I need to know the compression ratio and what heads are being used in order to run the simulation. At the very least tell me what pistons and what heads, and I should be able to calculate it pretty close.
Old Feb 3, 2007 | 09:00 PM
Ford150/428/dud
The pistons are keith black KB378
.020 over
if it helps it has a 28cc dish
Old Feb 4, 2007 | 10:07 AM
rusty70f100
Ok, we're getting closer. Do you have CJ heads or not? What is the casting number of the heads? It matters because of valve size and combustion chamber volume.
Old Feb 4, 2007 | 02:01 PM
Ford150/428/dud
I have the C6AE code on the heads.
Old Feb 4, 2007 | 07:59 PM
rusty70f100
Ok those are probably standard heads.
Ok, I'm coming up with 8.68:1 compression (based on 73cc chambers), 309hp @ 4000rpm, and 461ft-lbs @ 2000rpm.
I would suggest you change your head gasket selection to a Mr. Gasket #1132 steel shims for more compression. Then you'd at least have 9.08:1, again figuring 73cc chambers. That would raise the power output to 316hp @ 4000rpm, and 469ft-lbs @ 2000rpm.
Old Feb 4, 2007 | 09:33 PM
Ford150/428/dud
Hey thanks for the help
