1978 - 1996 Big Bronco
Bleeding the antilock
Old Jan 2, 2003 | 03:33 PM
2001ExcursionV10's Avatar
2001ExcursionV10
I was poking around under the Bronco this weekend and noticed a bleeded fitting on the rear wheel antilock unit. Should I bleed that unit when I bleed the brakes? My brake pedal seems like it will bottom out some times.
Old Jan 2, 2003 | 03:41 PM
JBronco's Avatar
JBronco
To the best of my knowledge, that is only used if you have to change the ABS valve (as I did).
Old Jan 2, 2003 | 03:58 PM
honney's Avatar
honney
You're supposed to bleed the RABS valve anytime you open up the rear line, but I very rarely do.
Old Jan 2, 2003 | 04:02 PM
Mil1ion's Avatar
Mil1ion
