Sponsored by: Auxito
royal purple
Old Feb 2, 2007 | 04:06 PM
c_cort's Avatar
c_cort
royal purple
anyone used this oil in there trucks? I'm due to change the oil. I've been using the motorcraft semi-syn, and i wanted to go full synthetic since its finaly getting cold here. any opinions?
Old Feb 2, 2007 | 07:10 PM
F-250 diesel's Avatar
F-250 diesel
never used it....friend uses it in his ram 5.9 and hasnt complained
i use amsoil though....in everything, tranny, diffs, tranfer case and engine.
i use the series 2000 0w-30 and their Ea oil filter....ive had great success with it and will continue to use it
Old Feb 2, 2007 | 07:14 PM
Bob Ayers's Avatar
Bob Ayers
All Royal Purple oil products are API certified, unlike Amsoil which has only 2 oil products that are API certified.....
Old Feb 2, 2007 | 07:16 PM
F-250 diesel
im not saying it isnt a good product....im sure its just as good as the rest, i just dont hear about it as much as amsoil, thats why i went with them
Old Feb 2, 2007 | 07:45 PM
bigdaddyII's Avatar
bigdaddyII
I used it before, for normal applications though I would stick with the MC.
Old Feb 2, 2007 | 08:16 PM
lariat97's Avatar
lariat97
I use RP in my truck. I have it in the motor & the rearend. Its good oil.
Old Feb 2, 2007 | 09:11 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
I use there 75W140 synthetic gear oil in my differential.
Old Feb 2, 2007 | 10:24 PM
Ultramagdan's Avatar
Ultramagdan
Has anyone checked out the oil and lubrication forum? A topic for sure.
https://www.ford-trucks.com/forums/forum70/
Old Feb 2, 2007 | 11:11 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Royal Purple is top of the line. All kinds of motorsports use the stuff!
Old Feb 3, 2007 | 10:37 PM
pursugr's Avatar
pursugr
I agree with ATC Crazy all of them motosports teams are using royal purple not the amsoil
Old Feb 4, 2007 | 04:03 PM
F-250 diesel
take a look at motocross and snowmobile racing....never seen royal purple....always see amsoil
Old Feb 4, 2007 | 04:10 PM
monsterbaby's Avatar
monsterbaby
Bob thats not totally true, not all the RP stuff is API, the race oils are NOT API certified, not that it's much of a difference but in the interest of honesty we need to let all the info out.
now as to RP, I have used it in my race engines for the past couple of years, and find that my bearings are living longer and the engine is keeping oil preasure better under the extreme conditions I put them through, I also noticed a 10 deg temp drop in my transmission, and the fact that it's not just burning the ATF up after a couple of races like I used to get with other oils.
Old Feb 4, 2007 | 04:47 PM
Bob Ayers's Avatar
Bob Ayers
Thanks for the correction Rob! The last time I checked the API site, it looked like all the RP products were API certified.
Old Feb 4, 2007 | 04:54 PM
monsterbaby
Bob this is a quote from the FAQ page of Royal Purple.
Originally Posted by Royal Purple
Royal Purple’s motor oils are formulated to provide unparalleled performance and protection and comply with API / ILSAC specifications. Its racing oils vary in viscosity and formulation as compared to the SAE motor oils to provide the greatest performance gains possible without regard to API, SAE and / or ILSAC specifications.
You are correct in regards to the SAE stuff, and all the other oils, just making the distinction of the racing oils not meeting that spec, although I think they went every bit as strict on the outcome but didn't bother to try and meet a spec put out by a agency that has government rules etc to follow.
