Engine Management
I guess I am looking for opinions on these two systems or other systems that might be out there.
Any advice would be greatly appreciated.
Spanish oak comes to mind. However, If it possible I would choose to use an OBD2 computer. It will have more programming options available, such as sniper or sct. I think any of the free tuners have a very limited support scope. A9L and A9M seemed to be the popular ecms. I still don't understand how Unichip works, but it and the Accel DFI and AEM setup should work. Here's some links.
http://www.accel-dfi.com/
http://www.unichip.us/
http://www.aempower.com/ViewCategory.aspx?CategoryID=62
http://www.motec.com/home.htm
Let me also state that this engine is running and performing quite well, I just believe that there is more availible if I can customize the parameters in the computer that is already in my truck.
Well, if what you want to do is to tune the vehicle, then you can contact us and we can set you up with a Racer Pro package that allows you to tune it yourself. And the SCT software does in fact work just fine on the EEC-IV PCM's, with hundreds of truck & Mustang owners using it on their EEC-IV PCM's.
Now when it comes to datalogging, if you are going to stick with that EEC-IV PCM, then your best bet for datalogging is to get a SNEEC unit for it - you have to jump on them when they are available, just hit Google and type in SNEEC and you will find the company - I don't have the link handy on this machine or I'd give it to you - anyway, the SNEEC is the bet device for datalogging an EC-IV type of PCM, you'll see more parameters so that it can actually be properly tuned, and the SNEEC generally works more reliably than any other unit for the Ford EEC-IV type PCM's.
I hope this info helps, & good luck!
That Sneec is exactly what I was looking for. Hopefully I can get one in March. After I find out what is happening inside the engine I will feel 100% more confident. That is one awesome tool. It is also cheap insurance and will save me a lotta $$$ in the long run.
I will definately keep you in mind for that Sct-Racer Pro system. I will have to do some research on it.
