Sponsored by: Auxito
Heater Fan Controls
Old Feb 2, 2007 | 12:04 PM
distol68's Avatar
distol68
Heater Fan Controls
Hi all,
Just found this forum, wish I had discovered it years ago! I have a '99 F150 4WD (extended cab, flareside but that doesn't really matter in this case I guess) with the 5.4l. My heater fan will only work on the High setting. Before I tear into the dash, has anyone else had this problem? I assume it's common as my boyfriend's '96 Ranger does the same thing.
Thanks for the help!
Old Feb 2, 2007 | 02:50 PM
KingRanchMan02's Avatar
KingRanchMan02
Your blower motor resistor is shot. You'll find it way up under the dash behind the glove box.
Old Feb 2, 2007 | 07:20 PM
distol68's Avatar
distol68
Thanks!
Thanks! That's the 4-pronged square blower motor switch, correct? I was really hoping to not have to tear into the dash . Oh well, better than a sharp stick in the eye!
Old Feb 3, 2007 | 09:31 AM
jimm66's Avatar
jimm66
I believe it should be a 4 wire connector going into the heater plenum behind the glove box. You shouldn't have to get into the dash.
Old Feb 3, 2007 | 10:17 AM
HomerWinzlow's Avatar
HomerWinzlow
Just a couple screws and a contortionist. I usually snap my body in half and pull my torso in leaving the rest outside. But its not too bad..
