Boost Leak from valve cover
Old Feb 2, 2007 | 07:46 AM
ro1bvan1's Avatar
ro1bvan1
Question Boost Leak from valve cover
I did a boost check the other day and noticed several small leaks around the map sensor, IC boots etc.. after fixing all of them I noticed the pressure would slowly leak down, I took off the crank case breather and air was excaping through the two holes from the crankcase breather in the valve cover on the driver side. is this normal? If not why would it be leaking from this point? Any ideas would help...
Old Feb 2, 2007 | 08:14 AM
Sabre2th's Avatar
Sabre2th
Some air is going to get past your piston rings, it's normal.
Tom
Old Feb 2, 2007 | 08:17 AM
ro1bvan1's Avatar
ro1bvan1
Thanks Tom, just didn't know if I should worry..Bobby
