Sponsored by: Real Truck
broken headlight switch
Old Feb 1, 2007 | 10:18 PM
gotfu's Avatar
gotfu
Cool broken headlight switch
I just pulled the **** off of my headlight switch and was wondering if any one knew if i can get just the **** or if a new complete switch is in order.
thanks
Old Feb 1, 2007 | 10:22 PM
gotfu's Avatar
gotfu
sorry
sorry the truck is a 2004 f350 crew psd
Old Feb 2, 2007 | 03:42 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE gotfu
Moved from the 6.0L section. You should find a better answer from the guys here.
Old Feb 2, 2007 | 11:29 AM
MobeyDick's Avatar
MobeyDick
That's the only thing I found about my 01 that I thought was sub-standard. I Babied it for 3 years until it finally came off. I glued it back on with one drop of Gorilla Glue. You have to be smart about using that glue it expands. Too much glue and it's in that position forever
It actually feels and works better then it ever did from the factory!! Been that way for about 3 years now, I don't baby it at all!!
Old Feb 2, 2007 | 03:17 PM
Leader's Avatar
Leader
It depends on what part of the switch you broke. The **** is used to remove the switch if it has to be serviced and if you glue it on, you can't take the switch out of the dash without destroying it.
Old Feb 2, 2007 | 09:31 PM
gotfu's Avatar
gotfu
just the **** is broken.if i turn the switch shaft to turn on the headlights or if i pull on the shaft to activate the fog lamps all works ok.looking at the shaft nothing seems broken just seems to be the ****.
