lifted or not?
Old Feb 1, 2007 | 09:08 PM
bigblue78's Avatar
bigblue78
Unhappy lifted or not?
ok, hope some body can help me,but i have a 1978 f150 4x4. it has 33 on it,i can find no evidence on a lift(blocks, longer springs,add ons)everthing i find says you need a 4"lift to fit 33" on a stock turck thats not a highboy.how can i tell what i have?
Old Feb 1, 2007 | 09:21 PM
77red4x4's Avatar
77red4x4
Welcome to the site!
Think I had 35s on my 74 with no lift but I had to bend in the corner of the fenders on the front to keep from rubbing. (perhaps I'm misremembering--it's been a few years ago)
Do you have pictures you can post? I noticed you have not yet created a gallery.
You can also get lift from a shackle flip. There are some threads about that and some members have pictures (ivanribic has pictures and a description of what he did--see https://www.ford-trucks.com/user_gal...&albumid=13227)
Old Feb 1, 2007 | 09:28 PM
bigblue78's Avatar
bigblue78
soory i dont, new to the site.but i need a lot of help with the truck to get to get it the way i want it
Old Feb 1, 2007 | 09:40 PM
77red4x4's Avatar
77red4x4
Here's a thread that might help you.
https://www.ford-trucks.com/forums/4...ight=tire+size
If you check my gallery I have 33s on with about 4" of lift. Planning on going with 35s once I've finished the body work, paint, etc and start actually driving it.
Old Feb 1, 2007 | 11:01 PM
Matts72's Avatar
Matts72
You should be able to fit 33s with no lift, however, there are discrepancies, my 79 f150 4x4 rubs with 245/75/16s which are 31" tall.
Old Feb 2, 2007 | 12:19 AM
73f350sc's Avatar
73f350sc
Most of these trucks can tuck 33's w/o rubbing stock (no blocks)..but keep in mind that sometimes things can vary depending on if the suspension is orginal w/ 30 + years of wear, or if its been freshened up. I guess to answer your question...it isnt unusual to be able to fit them w/o any modifications...I can on my 73 2wd.
-Chris
Old Feb 2, 2007 | 07:28 AM
79-400-POWER's Avatar
79-400-POWER
I have 31\10.50 mt on mr stock 79 and they rub a little when i turn, BUT for the same truck I have a set of 33\12.50 on offset rims and there is no rubbing.
On the rear i have even had 36 with no problame.
I f you have a sawzall you can clear about any size with some fender trim.
Old Feb 2, 2007 | 11:01 AM
scottie2hottie's Avatar
scottie2hottie
I have 33s on my 79 f150 no lift, no rubbing.
Old Feb 2, 2007 | 12:36 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
So the factory blocks have been removed? I removed mine from my 79 F-150 when I installed a leveling lift. I got new spring packs in the rear that were for a 4" lift but I removed the factory blocks. Better traction and less axle wrap. Oh and I have 33x9.5's and they clear with no problem.
Old Feb 2, 2007 | 12:38 PM
scottie2hottie
....and a much rougher ride. I did that on my 82, worst thing i ever did.
Old Feb 2, 2007 | 01:51 PM
FordTrucksKickGM
Really? My 79 with new coils and leafs rides better than my 99.
Old Feb 2, 2007 | 03:51 PM
bigblue78's Avatar
bigblue78
well thanks 2 all of you that helped out. i guess i'm just going to have to add a lift to fit 35's. now if i can only find away to fix the rust on the bed floor, i'll be all set.
Old Feb 2, 2007 | 04:14 PM
scottie2hottie
im talkin bout the rear. course my 82 is leaf all the way around that prolly don't help too much. it's got a 10 or 11 leaf stack out back- concrete has more give. 4stack up front compared to 2 from the factory, she's a buckboard.
Old Feb 2, 2007 | 04:18 PM
DaytonaTunnel's Avatar
DaytonaTunnel
Keep in mind just because the tires says it's a 33, doesn't mean it really is ! My Swampers measure a real 33", but they're the same overall heigth as my BFG 35's.
Old Feb 2, 2007 | 04:22 PM
scottie2hottie
rim width has a lot to do with that too. you can make a tire taller by using too narrow of a rim.
