Modular V10 (6.8l)
Tranny Flush
Old Feb 1, 2007 | 04:27 PM
jutahh1's Avatar
jutahh1
Tranny Flush
Is it neccessary to completely flush out the old convential ATF when replacing with synthetic?
Old Feb 1, 2007 | 07:35 PM
Mr Incredible's Avatar
Mr Incredible
The job's only half done if you don't. You'll be leaving in gallons of dirty ATF.
On the other hand, a drain and refill at quicker intervals has been mentioned before as an option.
I, personally, go for the once in 30k miles and forget about it.
Old Feb 1, 2007 | 08:16 PM
jutahh1's Avatar
jutahh1
I understand Mr. incredible, so if I drain the pan and converter, any residual convential fluid left shouldn't be a problem when adding synthetic ?
Old Feb 1, 2007 | 09:29 PM
Mr Incredible
I missed the synthetic part. Pardon me. I'm fixin' to do my trans fluid changeover soon and I've got it on the brain.
The important part is a full fluid flush to get rid of dirty fluid. Any residual non-synthetic will not cause you problems due to it being non-synthetic, but it's always best to get it all out...lines and coolers and all.
There's a procedure around here somewhere that tells how to do a full flush by yourself.
Ah...Here It Is...
Old Feb 1, 2007 | 09:50 PM
T- Squared's Avatar
T- Squared
When I drained the converter and changed the filter, it took 15 qts to fill her back up. The manual states a 4x4 has a 17.7qt capacity and a 4x2 has a 17.1qt capacity.
Old Feb 2, 2007 | 07:55 AM
SLE's Avatar
SLE
Thanks for that link incredible, save me some time searching! I'm gonna do mine this spring in anticipation of a good year of camping, lol! I'm doing mine kinda overkill since the truck only has 37k on the clock but a new trany was put in in 04' with 21k on the clock (planitary gear exploded going down the hwy). So in reality the trans only has about 17k on it but I'm gonna flush it and refill with Mercon V! Anybody have any Ideas what the dealership put in when they installed the new unit?? mercon or mercon V??? still seems highly debated!
Old Feb 2, 2007 | 08:13 AM
benr0's Avatar
benr0
I have changed mine twice, at 30,000 and at 60,000 both with Mobil1-Syn.
It is not that hard to do yourself.
Someone wrote a process to do this.
It will be as good as a flush IMHO.
Also when you do the tranny, why not get a couple of additional qt's and take the turkey baster treatment to the PS fluid?
waterboy_fishing
Apr 17, 2016 10:45 AM
Headviking
Apr 3, 2013 09:11 PM
Whitey Ford
Mar 19, 2010 01:28 PM
tndiesel
Aug 25, 2008 12:52 PM
Paarrothead
Oil & Lubrication
Aug 25, 2002 04:03 AM
