Airbag rear suspension?
Originally Posted by Indy_Gearhead71
Gm had something similar to a 4 link setup that they used on the old Chevelle's and Grand Prix's, even some years of the El Camino, not too sure about Ford, let alone how they are under extreme weight.
Limousine at the VERY least... I was looking to get just the links off of another vehicle and fab up brackets.
I got it!
Ford Fox body!
I just replaced the suspension on a 1988 T-Bird. (Mustang is the same car.) I can duplicate that for the lower link, just upsized. Extruded box steel or rectangular steel tubing with U-bolts should do the trick.
It had stamped steel that attached to a bracket on the body, then came down diagonally under the axle and bolted to a bracket on the rear of the axle... Between the axle and the point where it attached to the frame, it had a flat perch for a coil spring... Replace the coil spring with an air bag and I should be good.
glsurratt
16
05-22-2015 04:08 PM
86fordtruck
01-01-2012 12:44 PM
PRO-871
13
05-10-2011 12:05 AM
cigarxtc
03-02-2005 09:10 AM
