code scanners
Old Feb 1, 2007 | 08:09 AM
Minnesota Sun Bird's Avatar
Minnesota Sun Bird
Red face code scanners
I have a 2004 F-250 SD 6.0 PSD. What code scanner would any one suggest for someone who was a so called "shadetree mechanic" back in the sixtys when things were not so technical with engines. it is not my intention to go into the trade, only want to keep and eye on things and have a better idea on what's going on. I may want to have the ability reset codes if that didn't add a lot to the cost of such a scanner.
Old Feb 1, 2007 | 09:37 AM
eb2006's Avatar
eb2006
You might want to take a look at the ScanGuage II. It is a real simple device that will read and reset the codes plus it allows you to see some other engine info as well. All you have to do is plug it into your OBDII port and you are done! www.scanguage.com
