1978 - 1996 Big Bronco
temp gauge
Old Feb 16, 2000 | 08:47 AM
Boss_358's Avatar
Boss_358
temp gauge
Old Jan 3, 2003 | 04:21 PM
brokenbronco484's Avatar
brokenbronco484
temp gauge
i am having some problems with my temp. gauge. I can be driving for hours and it will never completely come off co the cold mark. I still works a litlle bit and the gauge will acually rise and fall but only a fraction of an inch. The hottest i have ever seen my gauge was at the n on normal and that was after 5 hours of highway driving. I just replace my radiator because it had a hole, but this didn't affect the gauge at all.
do i have a serious problem here or do i just need to replace my gauge? I am worried that I am running hot and I don't about it
thanks
90 XLT 302 K$N air intake dual flowmaster 3:55 gears
Old Jan 3, 2003 | 04:38 PM
JBronco's Avatar
JBronco
temp gauge
Mine used to be the same way until I put in a 195 degree thermostat. You might have a 160 in there, or no thermostat at all.
Old Jan 3, 2003 | 10:54 PM
greystreak92's Avatar
greystreak92
temp gauge
Before you go pulling the thermostat, you might want to check the temp sensor in the block. Factory sensors are heat reactive resistance types and will change their resistance qualities with age as ALL resistive components do. Also make certain its not leaking and that there is a good contact with the wiring. It doesn't take much to lose a good contact and all these factors can adversely affect it.
Old Jan 4, 2003 | 12:14 AM
RyanGruhn's Avatar
RyanGruhn
temp gauge
Replace the therm. Its cheep, takes 15 minutes and the truck probably needs it replaced anyways. I had the same thing happen to me and the themostate fixed the problem.
Ryan
Old Jan 4, 2003 | 03:33 AM
pooks's Avatar
pooks
temp gauge
I had the exact same problem with my 90 5.8L XLT - the temp wouldn't go above the N, and if it did it was overheating by the time it was half way up. Changed the rad cap and the thermostat and it's running normally now.
Pooks
1990 Bronco XLT 5.8L
31x10.5x15 Kumho's
Old Jan 4, 2003 | 06:59 AM
ryan cornell's Avatar
ryan cornell
temp gauge
I had the same problem also, just replaced the thermostat and it seemed to be the problem. I'll see in the spring/summer to be postive.
Old Jan 5, 2003 | 05:18 PM
brokenbronco484
temp gauge
thanks for the info I replaced the thermostat and the gauge works fine now
Old Jan 5, 2003 | 07:14 PM
Dutch123's Avatar
Dutch123
temp gauge
I have the same temp guage prob. It rides on the "N" or alittle off.
6 years, should I change?
