Sponsored by: Kumho
adding leafs your suspension
Old Jan 31, 2007 | 07:38 PM
clunker86's Avatar
clunker86
i have a 86 f250 400 c6 4x4 with leafs all the way around. i was wondering if you can add some extra leafs to your front leaf springs to get a bigger lift? can this be done and is it safe?
Old Feb 2, 2007 | 06:14 AM
SRD4X4's Avatar
SRD4X4
You don't want to try and lift a TTB with just springs (unless you just want to restore to original height).If you go more than 1 1/2-2" you'll most likely run into a camber problem.With axle drop brackets (that match the lift) and a pitman arm you can go more.
