Another newboy help with dataplate post
Old Jan 31, 2007 | 05:06 PM
ocoee's Avatar
ocoee
WB COLOR TYPE/GVW BODY TRANS AXLE
117 D F 101 SF4 06X
04360 24
MAX GVWR 1979 DSO
VIN F10GNEJ1913
Thanks
Old Jan 31, 2007 | 06:24 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
117 D F 101 SF4 06X
04360 24
MAX GVWR 1979 DSO
VIN F10GNEJ1913
Thanks
It kinda jumbled. You need to line these codes up a bit better.
Dennis has easier to use refs..vvvv see below vvvv
Old Jan 31, 2007 | 06:32 PM
Mil1ion's Avatar
Mil1ion
The X in 06X means power steering with Adjustable Column * Tilt*
F is probably the Trans code for the Warner 4 speed
117 is 117" wheelbase
SF4 - is the trim code
S= seat type (new for 79)
F= colour (new for 79)
4= Styleside
101- Body GVWR code = 4800 lbs
EJ1913= your truck was built in arpril 1979
check your plate here as well on my page to verify.
It covers a few years with some things but moreso for 77-79
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old Jan 31, 2007 | 11:07 PM
ocoee's Avatar
ocoee
It didn't present out like I typed it at all
WB-- 117 (Short wheel base)
Color-- D (some kind of copper)
TYPE/GVW --F 101
BODY --SF4 (Styleside)
TRANS --J
AXLE --06X
Old Feb 1, 2007 | 12:44 AM
NumberDummy
Color-- D (some kind of copper) Medium Vaquero Metallic
TYPE/GVW --F 101= F100 4x2 4800 GVW
BODY --SF Cordovan Vinyl (Explorer)
4 = ? (possibly Explorer Model)
TRANS --J = Ford 3 Speed Automatic
AXLE --06 2.75-1 Ford 2.9M
X=?
F10 = F100
G = 302
N = Norfolk VA Assy Plant
EJ1913 = 1979
Explorer was a Ford Truck trim line (like XLT, or Ranger), before it became a separate model.
Old Feb 1, 2007 | 01:12 AM
Mil1ion's Avatar
Mil1ion
Bill,
The S in SF4 means = Broadcloth & Vinyl Bench Seat (Explorer)
The F = Interior colour = Cordovan
The 4 means = styleside box
The X in 06X means power steering with adjustable column (Tilt)
Didn't you read my reply above ? .
It's in there
Old Feb 1, 2007 | 04:41 AM
NumberDummy
Smile
Originally Posted by Mil1ion
Bill,
The S in SF4 means = Broadcloth & Vinyl Bench Seat (Explorer) Dennis, 1979 Ford Light Truck Parts Catalog, Interior Trim 1979, shows Code "SF" to be Cordovan All Vinyl.
(I have extra fiche 73/79 LT..I'll pass them along gratis, if you like.
Didn't you read my reply above ? Yes, Sir...but since you already listed X and 4..I demurred. because OP already had info...
It's in there
You have better VIN refs (in most cases) and are faster on the trigger...while I'm squinting at microfiche, you've already fired!
Old Feb 1, 2007 | 11:13 AM
ocoee's Avatar
ocoee
UYes I read your site
problem is somethings don't match up
It is an Explorer but has no adjustable steering column, and I didn't see a J trans code.
I was hoping that it would tell me if it was a C4 trans or C6
Old Feb 1, 2007 | 02:12 PM
4starcstms's Avatar
4starcstms
Hey Guys.. Ive got a 79 F100, I dont really need the WHOLE vin decoded, just the trans code of K and the axle code of 11J *im assuming its refering to power Steering..
Thanks For the help ya'll!
Old Feb 1, 2007 | 02:28 PM
NumberDummy
K is a three speed auto, J refers to power steering..there's no 11 (rear axle code) listed in the parts book past 1978.
Old Feb 1, 2007 | 02:48 PM
Mil1ion's Avatar
Mil1ion
4star,
what are the last 6 digits of the vin#
The last Code 11 I have listed was in 75 and it was a 4.11
pre-75 code 11 was a 3.50 axle
Old Feb 2, 2007 | 03:36 AM
4starcstms's Avatar
4starcstms
The trucks @ the shop, It'll be the weekend before I can get the rest.. I need to lay under it and see if its a C4 or C6 ... thanks for the input.. I'll get the full VIN this weekend.
