charging issues
Old Feb 8, 2007 | 02:21 PM
Mil1ion's Avatar
Mil1ion
Originally Posted by dzjammer
BTW, the regulator needs screwed down and grounded or it makes your headlights flash like a disco going down the road.
see my posts in threads about flickering lights in the 73-79 telling users to clean and secure the voltage regular mounting area
Old Feb 8, 2007 | 05:28 PM
dzjammer's Avatar
dzjammer
I can't disagree with either of you. The more I think about it, I'm tempted to add a ground wire from the battery to the inner fender/radiator support. I think the light flickering is directly caused by the alternator charge/not charging. They don't completely go out, just dim down and then really bright. Is there a chance my charge wire is rubbing and grounding out, but not enough to burn through the fusible link? I'm in the house with a sick kid tonight or I would investigate now.
Old Feb 8, 2007 | 06:43 PM
Mil1ion's Avatar
Mil1ion
There should be:
A ground strap from the firewall to a head,engine block or intake manifold.
A Ground cable from battery to engine block.
I haven't ever seen a ground strap from a fender to the frame or battery.
Old Feb 9, 2007 | 12:02 PM
Franklin2's Avatar
Franklin2
Doubtful. If it hits, sparks will fly and it will get the fusible link. The only thing that ever usually goes wrong with that wire is sometimes the factory will have a splice up in the loom, and it will corrode. You have to unwrap the wiring to see it.
Old Feb 10, 2007 | 09:13 AM
dzjammer's Avatar
dzjammer
The ground cable to the block is good, not sure if I reconnected the one to the firewall from the intake last time I rebuilt the engine. I will try that today and see how it affects the problem.
Old Feb 10, 2007 | 03:50 PM
dzjammer's Avatar
dzjammer
Success!! I ran a ground wire from the battery post to the regulator mounting screw and for good measure, continued it on to the firewall. I re-connected the amp gauge directly to the battery post instead of the solenoid. Drove it all day with no radio cut-out and amp meter sitting steady at near 0 after initial recharge after starting. I should have figred this out sooner. Thanks to all.
toymachine13
401, 477, & 534 SD Engines
Dec 21, 2011 06:37 PM
phurst
Jul 6, 2011 03:51 PM
m3buzz
Electrical Systems/Wiring
Jul 20, 2010 12:29 PM
Meilichios
Jan 4, 2005 07:00 AM
jimbo81587
Nov 18, 2004 02:32 PM
