I have a 390 I just bought and I pulled the pan and looked at one of the rod bearings after taking off one of the caps and it was tapered to one side in the middle with some copper showing. Should these be replaced? I really don't want to overhaul the motor at this time. If so can I just put .010 in again? Thats what they are now. I( don't want to pull the crank to have it ground down or nothing.
Well if you have taper in the bearing..either the rods werent re-sized when the crank was ground bt .010"... Or the crank has a taper in it..... Both of wich will throw off bearing crush...
But if your just trying to Limp it along..change the bearing and go on about your biz..But thats not the proper way to do it?? But its your motor... JMO..
Generally, as the bearing wears, the grey wears away and shows copper, and even in completely stock original-from-the-factory motors, the copper will start showing on one side first. Probably the line-bore is a little off.
I'm assuming the motor didn't knock before you did this?
Sounds like normal wear - how does the crank look? Is it scored? Or shiny and perfect?
Just throw another bearing in there... but what you're looking at is just normal wear... probably
Unless that taper is really obvious, like you can feel it with your fingers...
