Voltage drop when it's cold?
Old Jan 30, 2007 | 08:33 PM
Bruker's Avatar
Bruker
Question Voltage drop when it's cold?
This morning when I got up and flipped on the lights things didn't seem as bright as usual. I figured I was still half asleep and didn't think any more about it. Tonight I noticed it again so I went and checked the voltage at a socket with a voltmeter and the reading was only 105 volts. We're having a cold snap (~10 deg. F) and was wondering if this is typical for these kind of conditions.
Old Jan 30, 2007 | 08:36 PM
FTE Herman's Avatar
FTE Herman
I know we had a drop once (measured at 98v). It was due to a blown transformer and the temporary they were using was not quite right.
I can't say it's not due to the cold but typically the highest electrical demand (and the potential for brown-outs) is typically in the summer.
Old Jan 30, 2007 | 10:21 PM
rikfish's Avatar
rikfish
It is normal, as the load on the system increases, voltage will drop. The load on the transformer that feeds your house (and others) was probably quite high due to higher electric useage from electric heat, blowers, even normal household appliances being used. One place I worked a few years ago had all kinds of problems with low voltage in the plant, due to the transformer feeding our incoming power was being pushed to it's limits. We had to install another power feed in, with another transformer to correct the problem. The voltage drop varied depending upon the time of day of course.
Old Jan 31, 2007 | 12:41 PM
Mil1ion's Avatar
Mil1ion
The last time that happened to me the "Neutral" wire at the power pole had been pulled away from something.
City Electric came and fixed it.
tseekins
Sep 29, 2011 08:08 PM
Vinford
74
Dec 23, 2008 06:45 AM
150ford
25
Mar 13, 2006 02:22 PM
weadjust
Jun 17, 2005 07:50 PM
King Triton
15
Mar 28, 2004 09:16 AM
