distributor
Old Jan 30, 2007 | 03:52 PM
smelser125's Avatar
smelser125
distributor
does any one know which way the dist turns? clockwise or counterclockwise and are the odd number cylinders on the passanger side 89 302
Old Jan 30, 2007 | 07:07 PM
subford's Avatar
subford
It turns counterclockwise and the cylinders on the passenger side are 1, 2, 3, 4 (front to back).
Old Jan 30, 2007 | 07:42 PM
smelser125's Avatar
smelser125
thanks tuned it up and no different still a steady miss that gets worse under load so i remembered that my grandfathers truck had the same problem a couple of years ago it turned out to be bad intake gasket so i pulled the plunem tonight and found the rear corner bolt finger tight and someone put rtv on the old gasket will put a new one on tommorow and let you know if it fixed it or not
