Sponsored by: Real Truck
Part Identification
Old Jan 29, 2007 | 01:30 PM
enduringexplorer's Avatar
enduringexplorer
Question Part Identification
When replacing the driver front fender of my brothers Superduty, I noticed an electrical control box with a High Voltage warning. Does anyone know what this is for? I know it's not the IDM, but it says IDM on it.
The top line reads: IDM 120 SREO
Anyone know what this is?
Old Jan 29, 2007 | 05:28 PM
ReAX's Avatar
ReAX
Is that the red cover on the inner fender well. I poped that open and it is just a bolt style terminal to connect two large wires.
Old Jan 30, 2007 | 06:34 AM
enduringexplorer
No, this is shaped like the IDM, and is mounted to the front of the cab. It would be about the same spot as the kick panel, but it's on the outside of the cab. It has a very large plug and a wire harness about 1" in diameter that is black with a red stripe. A label on the part says warning-high voltage, and not to pinch the wiring. Is there a way to add a pic?
Old Feb 2, 2007 | 08:32 PM
Fordtech1's Avatar
Fordtech1
If the base part number is 12B599 it is the IDM (Injector Driver Module) and the high voltage wires fire the injectors. The ECM or PCM is inside the cab next to the parking brake.
Old Feb 2, 2007 | 08:57 PM
Slipperyrock's Avatar
Slipperyrock
Walks like a duck...talks like a duck...must be the IDM.
Old Feb 3, 2007 | 02:39 PM
enduringexplorer
When my Superduty broke down in Atlanta a couple of years back, they replaced the module under the dash and called it the IDM. I think Bullydog calls the one under the dash the IDM also on their instructions for their flip chip. Even pics of IDM's on Ebay show the underdash unit. Is this common nomenclature for the unit under the dash also?
