1978 - 1996 Big Bronco
Spark plug gap...TFI question
Old Jan 13, 2003 | 09:59 AM
Wierdbeard's Avatar
Wierdbeard
Does anyone know what the plug gap should be 93/5.0? My Chiltons says.044, sticker under the hood says .052-.056. I just pulled a plug (new-I didn't put them in, though), and they are set at .039?
Also, I noticed the TFI is not mounted on the distributor, what year did they stop doing that? I know my 91 is on the dist., and just assumed it was there on the 93.
Thanks for any input.
WB
Old Jan 13, 2003 | 12:30 PM
fcarruth's Avatar
fcarruth
I think that most 5.0's use .44 gap. My 89 does and I remember reading somewhere in this forum that all 5.0's do as well.
Can't help you on the module question though.
Old Jan 13, 2003 | 03:37 PM
greystreak92's Avatar
greystreak92
They moved the TFI in 92 to the driver's side inner fender to help reduce heat related failures of the TFI module. The module is still sitting in a huge heat sink over on the fender.
Old Jan 13, 2003 | 03:48 PM
Steve_Uzi's Avatar
Steve_Uzi
Old Jan 24, 2003 | 01:07 AM
PMD66's Avatar
PMD66
Always tune by the sticker as it includes running changes specific to your engine. Use the gap stated on it, not Chilton's.
Old Jan 24, 2003 | 07:39 AM
steve83's Avatar
steve83
I agree with Duane.
Old Jan 24, 2003 | 11:17 AM
Wierdbeard's Avatar
Wierdbeard
Thanks guys. I'll re-gap this weekend. What running problems, if any would you get if they are gapped too narrow?
Old Jan 24, 2003 | 11:38 PM
PMD66's Avatar
PMD66
There is a miss and loss of power at higher rpms. BTW - I noticed in my Motor repair manual that it also says to use the sticker over its own specs.
Since you are doing the plugs... I can't resist: try the AC Delco Rapidfires or the Bosch 4 prong platinums, maybe the triple prong platinum Splitfires, and 8MM or better premium wires. Get an MSD 45KV coil (Accel or whatever brand name that makes a drop-in 42KV plus coil for your 5.0).
Might be a tad pricey, but you'll think you have a new truck when you stomp on it!
Old Jan 25, 2003 | 01:58 PM
steve83's Avatar
steve83
Those gimmick spark plugs are a waste of money, time, & gas. Stick with conventional Autolites.
Old Jan 25, 2003 | 02:36 PM
SmaulzEB's Avatar
SmaulzEB
Have to agree with that. Spent the money on the bosch 4 prong platinums, and received absolutely no benefit re: hp, throttle response, mpg, anything. Was basically a waste of money.
Old Jan 25, 2003 | 04:54 PM
greystreak92
I agree 100% on the "gimmick" plugs. The set of Bosch Platimuns I bought have actually been worse than the Champions I have run in every other car I ever owned. Some things are just better done the old fashioned way.
Old Jan 26, 2003 | 08:58 PM
PMD66's Avatar
PMD66
You guys must not be doing it right!
I've done the same thing on AMCs, Studebakers, Chryslers, GMs, Fords, Volvos, Triumphs and all showed a definite improvement over the stock ignition setup.
Now, if you are saying the premium plugs don't do much all by themselves - other than the benefits expected from installing new plugs - I might give an inch on that. But as part of a total ignition upgrade, the premium plugs do provide better high rpm performance than stock copper styles.
Try it!
