Cam replacement.
Old Jan 29, 2007 | 11:41 AM
lewislynn's Avatar
lewislynn
Cam replacement.
Can I replace a cam without replacing the bearings? I'm going to install a new timing chain and gears so I was wondering how much harder it would be to replace the cam too.
Old Jan 29, 2007 | 12:04 PM
smitty302's Avatar
smitty302
It would not be that much harder to change the cam,you would just have to pull the intake off.The old cam bearings should be alright.
Old Jan 29, 2007 | 12:15 PM
darrin1999's Avatar
darrin1999
and dont forget to replace the lifters too, and if youre going much of a cam youll need to replace your springs too, and when you break in the new cam make sure you use break-in additive or diesel spec oil or youll probably wipe the new cam
