1978 - 1996 Big Bronco
trans problem
Old Jan 11, 2003 | 05:48 PM
fast eddy's Avatar
fast eddy
Post trans problem
1991 e.b. bronco, between 30 and 40 mph. i get a vibration that seems to come from the trans. but a friend sitting in the shotgun seat says that he feels it under his feet. it does not happen all the time. when it happens i can move my foot of the gas and it quits. put the gas down again and it does fine. over 55 on the interstate no vibs at all. it seems to me that this happens more going up hill? guys i need your best guess. one guy says this happens with push button overdrive?
i'm keeping the bronco no-matter what. i have waited 30 years for a 4X4 next to scouts it comes close. ed
Old Jan 11, 2003 | 06:10 PM
screwy's Avatar
screwy
trans problem
[updated:LAST EDITED ON 01-11-03 AT 07:10 PM (EST)]Kinda sounds like the drive shaft. But I’m no expert.
96 Bronco, Eddie Bauer, 351w
Old Jan 11, 2003 | 06:57 PM
blownbronco's Avatar
blownbronco
trans problem
Do you have automatic locking hubs. I ask this because, under the feet of the driver is frontwheel drive shaft. Now if you have automatic hubs they could be stuck in the on position along with your 4X4 which will cause a ##### load of vibration. Ever try driving around town in 4X4 that's what happens!!
Old Jan 12, 2003 | 05:15 AM
fast eddy's Avatar
fast eddy
trans problem
what would i look for on the drive shaft
Old Jan 12, 2003 | 05:18 AM
fast eddy's Avatar
fast eddy
trans problem
>what happens!!
ed: thanks i'm new to all this, it has push buttion.
Old Jan 13, 2003 | 04:39 PM
Jeepincj7's Avatar
Jeepincj7
trans problem
Could be a number of things. Bad u-joint in driveshaft, loose wheel bearings, bad hub, etc. Climb under it and grab the driveshaft. Try to move it back and forth and look for movement in the u-joint. Shouldn't be any. Check both shafts.
To check wheel bearings, jack up the front and then move the tires back and forth vertically. Should be zero play if good.
Could also be a tire out of balance. Take it to walmart and get them balanced for $5/ea.
Old Jan 13, 2003 | 04:59 PM
brown 4x4's Avatar
brown 4x4
trans problem
Old Jan 24, 2003 | 11:17 AM
Broncobigtire's Avatar
Broncobigtire
trans problem
try checking your atf fluid that what i did and it fixed it
