General Automotive Discussion
antifreeze concern
Old 01-28-2007, 11:15 PM
thefarelaneman's Avatar
thefarelaneman
thefarelaneman is offline
antifreeze concern
Just what determines how much anti freeze is enough. I know that water will freeze at 30degrees. How cold does it have to get to be a real danger.How long does it take for a fully warm engine to cool down. just wondered. I just replaced the termostat and there is nothing but water in the engine. It is supose to get to 20 degress tonight, but the van is sorta between the house and shop and at 1230 am I plan to let it run till its warmed up .......
Old 01-28-2007, 11:25 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
No way to tell, there are too many variables. You will just have to start it every hour or so until you get a 50/50 mix back in it. Put a blanket etc over the hood and grill to help keep the heat in.
Old 01-28-2007, 11:44 PM
Zip's Avatar
Zip
Zip is offline
I suppose you could drain the system again and refill in the morning.
Old 01-29-2007, 11:39 AM
Nitramjr's Avatar
Nitramjr
Nitramjr is offline
I'm sure you know by now whether your block survived the night but I am guesing you were fine. Assuming you got your water up to 190° at midnight like you mentioned and didn't touch it again, you would have 7 or so hours before the outside air temp starts to rise again. Getting the water from 190 down to 32 takes a good amount of energy loss. Getting it to freeze is another matter. It takes a lot of energy being removed from a quantity of water to go from 32° (liquid) to 32° (solid, as in ice). 20° probably isn't a large enough temperature differential to get the water to freeze in just 7 hours.
Hope I'm right.
Old 01-29-2007, 01:17 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Those antifreeze testers with the floating ***** are pretty cheap.......cheaper than an engine block anyway.
Steve
Old 01-29-2007, 02:34 PM
94van's Avatar
94van
94van is offline
Most every container of anti freeze I've seen, has a chart on it showing the amount needed.
In most cases, a 50/50 mix is good.
According to my genuine Prestone° jug, a 50/50 mix gives you protection to -34F.
70/30 gives you -84F
Old 01-29-2007, 03:04 PM
thefarelaneman
I had no problem. It takes alot for an engine to hard frezze but Im going to put some antifreeze in today , thanks
Old 01-29-2007, 03:26 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
If you do not have the money to refill the whole system, then two gallons of 50/50 mix should be enough diluted with water to get you by.
Just run the vehicle until it gets hot enough to open the thermostat.
I agree with the 20 degrees, wind is a big factor. If you put cardboard in front of the radiator that will retain the heat much longer. Just a trick when you go hunting or something where the vehicle will sit while you are out of the truck.
Old 01-29-2007, 03:33 PM
Mr Incredible's Avatar
Mr Incredible
Mr Incredible is offline
The real danger is trying to "get by" and hope nothing happens. I usually don't get the clean end of the stick on those occasions.
Hope everything came out alright...
Old 01-29-2007, 05:27 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Glad to hear your 'Star survived the night. Because you didn't open the block drains you had some antifreeze mixture trapped in there (if it was there before), but 20* is pushing your luck.
Steve
Old 01-29-2007, 05:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
Wind speed and direction is a BIG factor, as well as temperature. That is why it is impossible to quantify how long it will take to freeze.
Old 01-29-2007, 10:10 PM
thefarelaneman
I solved the problem I think,Tonight I will park it in my heated garage. Sorta tight with my fairlane hoggin up the place but a short aerostar doesnt take up much room...
Old 01-30-2007, 08:06 AM
Mr Incredible
You know.....you could've had a jug of 100% in it by now....
Old 01-30-2007, 09:50 AM
GLR's Avatar
GLR
GLR is online now
Anti-freeze also helps cool the engine and keeps it from boiling over, fights corrosion and is usually a requirement on A/C equiped vehicles.
