1978 - 1996 Big Bronco
pitman arm
Old Jan 14, 2003 | 07:41 PM
VIBR8R's Avatar
VIBR8R
pitman arm
What and where is it?:-X23
Old Jan 14, 2003 | 07:54 PM
teflon_80's Avatar
teflon_80
pitman arm
The pitman arm is the funny shaped joint that connects the power steering box to the steering linkage. If you look directly under the front of the truck you should be able to see it right behind the stabilizer bar. Also the other question you asked about the whinning in the rear is almost definatley the fuel pump. One way to tell for sure is to turn the key to run without starting the vehicle. You sould be able to hear that same noise.....
Old Jan 14, 2003 | 09:13 PM
VIBR8R's Avatar
VIBR8R
pitman arm
Thanks for the input Ill try it in a little bit.
Old Jan 14, 2003 | 09:49 PM
steve83's Avatar
steve83
pitman arm
