Well I had another GPR go bad on me last week. Same problem too - the battery side terminal broke loose. Did some research and decided to go with the Stancor DC contactor. Then I found a couple of threads on another website where some folks were griping that the Stancors were just as unreliable. I still figured that the Stancor was better, but it could still go bad with as little warning as a regular relay, and since the temps up here have really dropped lately, I decided that I needed something to ensure that the truck would always start.
So what I did was buy 2 contactors and wire them up in parallel (battery lines) and put the control power lines on a switch. I mounted everything in a Radio Shack project box and mounted the whole thing next to the washer reservoir. I totally cut out the connections under the engine cover and soldered in some trailer disconnects for the control power, and used a quarter inch bolt to connect the battery lines, and taped them up real good. The switch I used is a On-Off-On so I can switch between contactors or just turn them off for the warmer weather.
So what I have now is two contactors mounted away from the engine (I am hoping the reduce vibration will let them last longer) in a totally removable module that I can easily disconnect and work on inside where it is warmer. Is it just me or do the GPRs only fail in January/February?
I know my previous post kind wasn't exactly clear, but the temps have been in the single digits on numerous occasions, and I was able to get the truck started without too much trouble. All I was really trying to say was that the darn things never seem to fail unless it gets really inconvenient. That reminds me of another point - the Stancor units are rated for -40 C, and it doesn't get quite that low around here, but it sure seems to try.
Freak I agree with you that the psds seem to act up most in the cold. I also did not follow your first post, but thats ok I carry spare parts gpr, starter relay, cps, fuses, belt, and idler pully with tools to fix the mentioned.
