Aerostar Ford Aerostar
transmission modulator
Old Jan 28, 2007 | 02:19 PM
9d4's Avatar
9d4
Where is the transmission modulator located on my 94 awd aero. I have read that if these leak and your engine sucks in fluid you will develop a knock. I have been trieng to pinpoint a mysterious knock on my motor, more like a collapsed lifter noise that goes away when its put in nuetral or park. It's not the tranny.. 600.00 later and parts I didn't need, or the heads, 1.500 later
Old Jan 28, 2007 | 03:52 PM
copper_90680's Avatar
copper_90680
On the passenger side, near the cat. There should be a heat shield covering it up on the 4.0L models.
Did you already spend $600 on the transmission and $1500 on the heads?
Old Jan 28, 2007 | 04:36 PM
9d4's Avatar
9d4
Yes What a nightmare this has become. The mechanic that did the heads and valvetrain is supposed to take a look at it again
Old Jan 28, 2007 | 05:55 PM
96_4wdr's Avatar
96_4wdr
has the mechanic checked the flex plate that the TC mounts to and the crankshaft spacer between crank and TC...
when in park and N all strain is off both parts
both crack and break especially on the high torque high vibration 4.0L OHV
half way down page
http://www.transmissioncenter.org/a4ld.htm
Old Jan 28, 2007 | 06:43 PM
9d4's Avatar
9d4
Yes that was all replaced via the 600 even the tc and starter at the tranny shop. they said it was not in the tranny. Someone suggested that it could be a pilot bearing that fits in the crank?? Thanks for the link.
Old Jan 28, 2007 | 11:49 PM
xlt4wd90's Avatar
xlt4wd90
The automatic transmission does not use a pilot bearing; that's only used with a manual transmission to support the nose of the input shaft.
Did you try using an engine stethescope or a short length of hose to try to localize the noise?
Old Jan 29, 2007 | 01:41 AM
96_4wdr's Avatar
96_4wdr
time to change mechanic shops
Old Jan 29, 2007 | 06:37 PM
9d4's Avatar
9d4
xlt4wd90 Thats what I thought. I know on my GTO for my 4 speed I have a pilot bearing in my crank. But I figured he knew something I didn't
