Sponsored by: Auxito
Knock/Tick Help Please
Old Jan 28, 2007 | 11:40 AM
derfman's Avatar
derfman
I have a 97 f150 super cab 4.6 4x4 with approx 135k It has a engine noise that I do not seem to be able to hear when cold but can hear when engine is hot. Seems to go away upon acceleration. Does not sound like exhaust leak. I think it may be the catyilatic converter on the passenger side but not sure. Cannot hear from the top of engine and when I climb under It does not sound like it is coming from the lower end. It seems to be near the cat. converter.
Old Jan 28, 2007 | 08:28 PM
3-RANGERS's Avatar
3-RANGERS
Sounds like further investigation may be needed. But you're the only one that can hear it...Can you hear it when you let off of the gas after acceleration like from 55mph and then let off?
Old Jan 28, 2007 | 09:52 PM
firebug8109's Avatar
firebug8109
If you think it is coming from the catys, try taking it to a reputiable muffler shop and have them test the catys. Here, we have several shops that can test them to make sure they are working ok. I am not sure exactly how they do this, but i had a 1988 Ford Crown Vic that did something similar to what you are describing. My 302 was fine, but the catys were infact bad. Try that first, and then go from there. Good luck.
Old Jan 28, 2007 | 10:23 PM
derfman's Avatar
derfman
I cannot hear it when driving. Only when I sit and idle. So to answer your question it does not get worse wheen I slow down. Thanks for your help and waiting for any other suggetion you may have.
Old Jan 29, 2007 | 11:44 AM
bokker's Avatar
bokker
hi, this may not be related but my 4,2 has a loud tick when you stop and this is the cats cooling. here in uk its quite cold and you can here the tick real loud when walking away from the truck.
good luck bokker.
