CPS Question
Old Jan 28, 2007 | 10:28 AM
dmueller71's Avatar
dmueller71
Question CPS Question
I'm confused. When you guys start asking someone that's having running problems about their CPS. I've noticed you usually ask if the Tach is moving while cranking. I'm not having any running problems, that I know of, and my tach doesn't move while I'm cranking it. Is it suposed to? Is this a sign of an upcoming failure?
Old Jan 28, 2007 | 10:34 AM
Uzumati's Avatar
Uzumati
That is not a 100% sure test. Mine does Tenn01's doesnt both 01's. Any truck after 01 will not move because ford changed the wiring to the gauge in 02.
Old Jan 28, 2007 | 10:40 AM
clintbonnie's Avatar
clintbonnie
Mine is a 99 & it does not move either.. and runs great. Also just replaced my CPS about 8 months ago.. Like Alan says, it not a very good test. Just keep a spare in your glove box..
Old Jan 28, 2007 | 10:43 AM
dmueller71's Avatar
dmueller71
OK, I feel a little better now. I changed mine a couple of years ago when I had a pcm problem, so I still have the original. It had about 35000 miles of use. The one I have in there now has been good for another 115000
