horn location
Old Jan 28, 2007 | 08:17 AM
fordman 460's Avatar
fordman 460
horn location
I have purchased a 1989 F-250 diesel and the horn doesn't work. I checked it out and the relay works when the horn is depressed so I believe the horn is missing because I can't locate it. Where is the stock mounting location so I can install a new horn into the harness. Thanks
Old Jan 28, 2007 | 08:29 AM
cjclarke's Avatar
cjclarke
on my 88 f150 its on the front side of the core support under driver headlight close to the bottom, behind bumper, you will have to get to it from under the truck has a bracket w/two horns not sure if yours is the same but might be cj
