largest tires
Old Jan 27, 2007 | 10:48 PM
Bronc1's Avatar
Bronc1
largest tires
I have an 92' 4x4, 4.0L what is the largest tire size I can put on this stock Explorer?
Old Jan 27, 2007 | 11:58 PM
mrshorty's Avatar
mrshorty
Depends somewhat on who you ask.
After the Firestone fiasco, some tire shops won't even consider putting anything other than the OEM 235/75/15's. If you have a tire shop that will work with you, the usual answer for the biggest on a stock 1st gen is 31/10.50/15 or 265/75/15. I currently have 31/10.50/15 Dunlop Mud Rovers on my '92 and they fit fine. I get a little bit of rubbing on the plastic wheel well when turning as the suspension compresses, but it's tolerable. I would also rub on the sway bar at full left/right turn, if the front sway bar were installed.
