1978 - 1996 Big Bronco
Engine problem?
Old Jan 16, 2003 | 03:58 PM
Red_Bronco's Avatar
Red_Bronco
Engine problem?
I have a 1988 Bronco, (red/tan, eddie bauer, 5.8 efi) My truck has been sitting on the side of my house for 2 years and when I started it up the other day, the throttle responce was very poor, what could be the problem? fuel filter, injectors, spark plugs? I need help!!
Old Jan 16, 2003 | 04:04 PM
greystreak92's Avatar
greystreak92
Engine problem?
If its been sitting for two years without running (assuming I am reading the post correctly)my guess would be sticky linkage, dirty throttle body, corrosion at electrical connections, and just lack of lubrication to moving parts...oil change, tune up, clean electrical contacts etc. will all help.
Old Jan 16, 2003 | 04:08 PM
georgedavila's Avatar
georgedavila
Engine problem?
And possibly bad gas.
Old Jan 16, 2003 | 04:12 PM
greystreak92
Engine problem?
Definately....could, (most likely does) have a lot of water in it from sitting through summer heat/humidilty and cold.
Red_Bronco's Avatar
Red_Bronco
Engine problem?
[updated:LAST EDITED ON 01-16-03 AT 05:14 PM (EST)]no... I ran it about every 3 mo... and I put new gas in it after I started it up... man I'm young I'm just learning, any way what other things could be wrong? Oh, I already changed the oil
Old Jan 16, 2003 | 04:25 PM
Red_Bronco's Avatar
Red_Bronco
Engine problem?
