2004 Recall: Improperly formed frame flange
It says that some of the 2004's where recalled about this problem and if it is wrong than they replace your truck. Has anybody had this checked? I recieved 1 recall since I have owned the truck and it was for the transmission fluid additive.
I have received no other recall notice. I was wondering if anybody knows whats going on that way I can look into it further if needed.
Here is the link to the recalls on this site for 2004 Ranger.
https://www.ford-trucks.com/recalls/...y-2004/t-21028
Call your local dealership, they will be able to see if your vehicle is part of the recall program.
If it IS recalled, all they will do is inspect the frame. It will either pass or fail. If it passes, they give the vehicle back to you and you're done (it is a quick inspection they will probably do in the service bay.. takes a few seconds).
If it fails, Ford will give you a new truck. Good luck!
Also just so you know, the truck won't FALL APART or anything because of this frame defect... the reason for the recall is because on some the frame was not bent away from the fuel tank, and does not meet federal safety guidelines as a result (in other words, if in a serious accident, the frame could rupture the fuel tank and possibly cause an explosion).
Ford decided it would be more cost effective to just replace the trucks, rather than paying out the dealerships BIG $$$ to replace the frame (let alone customer satisfaction hits). Almost sounds like the SMART way to handle it for a change!
Originally Posted by Level2
Don't know what truck you have but this recall came out shortly after I bought my truck and was working at a dealership. I had a tech check into the recall and it was only on some reg. cab 4x2 models. If you have an extended cab then you have nothing to worry about.
CUSTOMER SATISFACTION PROGRAM
04B22 All 2004 and Certain 2005 Model Year Vehicles Equipped With 5R55S/5R55E/5R44E Transmissions 5R55S/E & 5R44E Transmission Fluid Additive
Frank M. Ligon
Director
Service Engineering Operations
Ford Customer Service Division
Ford Motor Company
P.O. Box 1904
Dearborn, Michigan 48121
May 27, 2005
TO: All U.S. Ford and Lincoln Mercury Dealers
SUBJECT: Update: Supplement Announcement
Customer Satisfaction Program 04B22 – Supplement #3:
RE: Customer Satisfaction Program 04B22 - Supplement #2 dated April 1, 2005
RE: Customer Satisfaction Program 04B22 - Supplement #1 dated January 2005
RE: Customer Satisfaction Program 04B22 dated January 2005
REASON FOR SUPPLEMENT #3
Program Extension:The expiration date for Customer Satisfaction Program 04B22 has been extended through December 31, 2005. Owners of affected vehicles will be notified of this extension via mail starting the week of June 1, 2005.
Urgency:The longer the factory fill transmission fluid remains untreated in the transmission, the greater the likelihood that it will adversely affect transmission shift performance and require a much more extensive repair. For this reason, it is very important that the affected vehicles have the transmission additive installed as soon as possible.
In-stock Vehicles:
At this time, only approximately 63% of the affected in-stock vehicle population has been serviced under this program. It is important that dealers continue to service their in-stock vehicles and complete the repairs as soon as possible.
Sold Vehicles:
It is equally important that dealers utilize their FSA VIN list to identify, contact, and encourage customers to schedule appointments to have this service performed as soon as possible.
PROGRAM TERMS
This program will be in effect until December 31, 2005 regardless of mileage.
AFFECTED VEHICLES
All 2004 and certain 2005 model year vehicles equipped with 5R55S, 5R55E, or 5R44E transmissions and built between Job #1 2004 through September 22, 2004.
Vehicle Line
Assembly Plant
Explorer (4 Door)
Louisville and St. Louis Assembly Plants
Mountaineer
Explorer Sport Trac
Louisville Assembly Plant
Lincoln Aviator
Lincoln LS
Wixom Assembly Plant
Thunderbird
Ranger
Edison and Twin Cities Assembly Plants
Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership, visit https://web.fsavinlists.dealerconnection.com. This information was made available on 01/06/2005.
REASON FOR THIS PROGRAM
The affected vehicles were originally filled with an improperly formulated transmission fluid that, over time, may cause delayed/harsh reverse engagements.
SERVICE ACTION
At no charge to the vehicle owner, dealers are to install one bottle of 5R55S/E & 5R44E Transmission Fluid Additive to each affected vehicle. This will correct the formulation of the transmission fluid and maintain the shift quality of the transmission.
NOTE: It is extremely important that all in-stock vehicles are repaired prior to delivery. This transmission fluid additive will prevent the delayed/harsh reverse engagements on vehicles that do not yet exhibit this condition.
Attachment I: Administrative Information
Attachment II: Labor Allowances and Parts Ordering Information
Attachment III: Technical Information
Attachment IV: Questions and Answers
Customer Notification Letters
QUESTIONS?
Claims Information: .................................................. .............. 1-800-423-8851
Special Service Support Center (Dealer Only) Questions: .......... 1-800-325-5621
Copyright © 2005 FORD MOTOR COMPANY
Published By: Recall/Service Programs Department
Frank M. Ligon
Director
Ford Motor Company
P.O. Box 1904
May 27, 2005
In-stock Vehicles:
Sold Vehicles:
PROGRAM TERMS
AFFECTED VEHICLES
Vehicle Line
Assembly Plant
Explorer (4 Door)
Mountaineer
Explorer Sport Trac
Lincoln Aviator
Lincoln LS
Thunderbird
Ranger
SERVICE ACTION
QUESTIONS?
SAFETY RECALL
04S19 DEMONSTRATION/DELIVERY HOLD:
Certain 2004 Model Year Ford Ranger Regular Cab Pickup Trucks - Frame Rail Inspection
Frank M. Ligon
Director
Ford Motor Company
P.O. Box 1904
July 2004
SUBJECT: DEMONSTRATION/DELIVERY HOLD - Safety Recall 04S19: Supplement #1
RE: DEMONSTRATION/DELIVERY HOLD - Safety Recall 04S19:
PURPOSE OF THIS SUPPLEMENT
Advise dealers that Customer Letters will be mailed and available to dealers on July 19, 2004.
Advise dealers that units that do not pass inspection will not be repaired.
Advise dealers to make arrangements to have sold and unsold units that do not pass inspection repurchased by their FCSD Zone Manager through the normal Reacquired Vehicle (RAV) process.
AFFECTED VEHICLES
Certain 2004 model year Ford Ranger regular cab pickup trucks built at the Twin Cites Assembly Plant from June 2, 2004 through June 25, 2004. Affected vehicles are identified in OASIS. In addition, for a list of vehicles assigned to your dealership, visit https://web.fsavinlists.dealerconnection.com.
REASON FOR THIS SAFETY RECALL
In some of the affected vehicles, it may be possible that the frames on short and long wheel base regular cab models have center rail section flanges that were not formed properly. In the event of a collision, an improperly formed center rail section could potentially puncture the fuel tank, resulting in a fuel leak. A fuel leak in the presence of an ignition source could result in a fire.
SERVICE ACTION
DO NOT DRIVE, DEMONSTRATE OR DELIVER any of the vehicles involved in this recall until they have been inspected per Attachment III. Vehicles that pass the inspection may be released; if a vehicle does not pass inspection, call the Special Service Support Center at 1-800-325-5621.
STOCK VEHICLES
Inspect all affected stock vehicles before demonstrating or delivering. Vehicles which pass inspection may be released.
If a dealer stock unit is found to have an improperly formed frame:
The vehicle will not be repaired and cannot be sold to customers.
Contact the Special Service Support Center at 1-800-325-5621 to verify the inspection; a digital photo or Ford on-site inspection may be required after calling.
When the Special Service Support Center has verified the inspection, contact your Market Area Team and request to have the vehicle uploaded in RAV-Fast.
Dealers should contact their Service Zone Manager to initiate the process to repurchase the vehicle from Dealer Inventory.
SOLD VEHICLES
Immediately contact any of your affected owners and schedule an inspection date. Inspect other affected vehicles identified in OASIS, which are brought to your dealership.
Owners of affected vehicles will be notified the week of July 19, 2004 and directed to dealers for inspection.
If a customer's vehicle is found to have an improperly formed frame:
The vehicle will not be repaired and cannot be returned to the customer.
Dealers should contact their Service Zone Manager to initiate the process to repurchase the vehicle from the customer.
The customer should be placed in a rental vehicle until a suitable replacement vehicle can be obtained.
OWNER NOTIFICATION MAILING SCHEDULE
Owners of record will be notified via first-class mail the week of July 19, 2004. Please note that dealers should inspect any affected vehicles that arrive at their dealerships, whether or not the customer has received a letter.
QUESTIONS?
Claims Information:...................................... ...........................................1-800-423-8851
Special Service Support Center (Dealer Only) Questions:...........................1-800-325-5621
Copyright © 2004 FORD MOTOR COMPANY
SAFETY RECALL
Frank M. Ligon
Director
Ford Motor Company
P.O. Box 1904
July 2004
AFFECTED VEHICLES
SERVICE ACTION
STOCK VEHICLES
SOLD VEHICLES
QUESTIONS?
Yes I miss my OASIS access too... I used to love the message boards.. and actually the online testing was a lot of fun too...
I watched the demo video of the crown vic police fire suppresion system about a hundred times! Watching that car jump 4 inches into the air when it went off was just wicked!
Anyways.. I loved the job.. hated the politics.. they let me go 3 days before my one-year anniversary and screwed me out of about $2000.
I was a technician at a local Ford dealer, Lou Fusz Ford. I had full access to fmcdealer.com
They turned it off three days after I was "let go".
I miss getting to "play" with all the new toys. I even got to drive a Ford GT around the parking lot a few times.. what a THRILL that was!!!
The guy who got to work on it got in BIG trouble for using an air impact on the underside panel bolts. He dropped a socket and it took him a couple hours to find it.. we all laughed at him.
edtahaney
1983 - 2012 Ranger & B-Series
05-29-2015 02:14 PM
F250OBX
02-04-2006 11:16 PM
