1978 - 1996 Big Bronco
Coolant overflow tank
Old Jan 11, 2003 | 07:09 PM
tothfngclw's Avatar
tothfngclw
I have read on here before where people have found that coolant had run out of the top of the overflow tank. Some suggested using duct tape over the fill hole and other options. I have had this happen a few times recently and tried the duct tape and found that it worked for a little while but after a few weeks I find coolant on top of the tank again. Just wondering what causes this and if anyone else has a fix that lasts. I was thinking that somehow I was getting to much pressure in the coolant system and it was causing it to expand and run over but I have a new cap and the system was flushed and refilled with new coolant in the fall so my thought was the cap should let go first. Any suggestions are appreciated.
Old Jan 11, 2003 | 11:02 PM
blownbronco's Avatar
blownbronco
First off the overflow tank is not under pressure at all. I used to have that same problem, I fabbed up new mounting brackets so the tank sits level, also I don't fill up over the line that indicates full!
Old Jan 12, 2003 | 01:21 AM
tothfngclw's Avatar
tothfngclw
Same here, only fill to cold line but still pushes coolant out through the top. The tank appears level, I will check again when it gets a little warmer out. Temps in the teens here.
Old Jan 13, 2003 | 04:22 PM
BurlyBoy's Avatar
BurlyBoy
Your rad cap might be bad - if its an old one you might want to invest in a new one (cheap).
Old Jan 13, 2003 | 04:32 PM
JBronco's Avatar
JBronco
I installed a brand new recovery tank (it had a leaky seam), also my radiator, heater core, and cap is new, and it still does it. I cover the hole under the coolant tank cap with aluminum foil, I mold the foil to stick down a lttle bit so it deflects most of the coolant, and it comes up around the top outside edge and snaps under the cap. I STILL get a little bit of coolant around the foil, but it does not get out and run down the tank. I can't believe that it is so hard to stop this. The cap on the tank is not even under pressure and it is a good few inches away from the coolant.
Old Jan 13, 2003 | 11:32 PM
steve83's Avatar
steve83
Either it's slosh, or your cap isn't sealing. Any radiator shop can test it for you.
Old Jan 14, 2003 | 08:48 AM
JBronco's Avatar
JBronco
It's just slosh as far as I can tell. Being that the tank is new, I would have to say that the cap is as tight as it's going to get. A lot of people have reported this, even on brand new trucks. It's just one of those things. There is nothing wrong with it, other than Ford's bad engineering, or use of low quality parts; most likely both.
Old Jan 14, 2003 | 10:20 PM
steve83's Avatar
steve83
[updated:LAST EDITED ON 01-14-03 AT 11:21 PM (EST)]I use a late-model overflow tank and mine NEVER leaks, even though I drive it like it's a 911. (Actually more like a 959 for you Porsche FREAKS! )
Old Jan 15, 2003 | 07:47 AM
fcarruth's Avatar
fcarruth
I have had my 89 since 91 and have never had this problem. I may be making up for it with other problems though. I don't see how this could be normal. Does FORD say it is normal ?
Old Jan 15, 2003 | 08:36 AM
JBronco's Avatar
JBronco
Of course Ford would not admit to it being a problem, but Ford mechanics will tell you that it happens all the time.
Old Jan 15, 2003 | 09:54 AM
greystreak92's Avatar
greystreak92
This dilema must be more common on older models because I have no such problems with my 92 and my overflow resevoir is missing a mounting tab so it bounces around more than most would I imagine.
Old Jan 17, 2003 | 11:27 AM
mbking99's Avatar
mbking99
Hello all,
I have had this problem twice with Ford. Once with a Mustang GT 89
and also with my current 96 Bronco 5.8l. With the Mustang I ended up replacing everything from the radiator to the water pump to the cap etc. Still with the same problem of coolant overflowing and 1300 hundred dallars less in my packet and at the Ford dealership it turned out to be the head gasket. Now with my bronco doing the exact same thing and not overheating I would suggest doing first a cooling system pressure test to look for leaks. Look at hoses, caps, oil cooler if you have one and look around the water pump gasket and both sides of the heads for leaks. I would also do a compression test. Use the gauge that is threaded rather than the one you just hold in the spark plug hold. You will get much better results. Its better to find out now than later when you have oil in your coolant overflow like I do now. I love Broncos but tired of Ford engineering and this will be my last Ford. I have had 3. Ford needs to put out better quality.
Regards,
Mike
Old Jan 17, 2003 | 12:42 PM
BurlyBoy's Avatar
BurlyBoy
Ha ha. I think that if you subscribe to any other forums (chev, dodge, etc.) I will bet you that you'll find that the same comments are made about those brands too...
Old Jan 17, 2003 | 02:30 PM
JBronco's Avatar
JBronco
I don't want to start anything here, but I have had more problems with Ford trucks manufactured after the 1980's than any other vehicle. My 1966 and 1972 F100's were bulletproof. But two clean used Ford trucks, and one new one, have had way more problems than comparable GM and Mopar vehicles. During the 1990's, I purchased three brand new trucks, one each from GM, Dodge, and Ford, My 1995 F150 needed far more warranty repairs needed than the other two combined. A clean used 1988 Ranger, purchased in 1992 with 78K, needed an engine at 88k. And you all know about my Bronco. I will not be buying any more Fords after this Bronco, except maybe a 1960's F100.
Old Jan 17, 2003 | 03:03 PM
brokenbronco484's Avatar
brokenbronco484
