1966 - 1977 Early Broncos
Lift blocks
Old Jan 26, 2007 | 08:29 PM
bc56845's Avatar
bc56845
Lift blocks
Is anyone running lift blocks? I've always used blocks in my trucks but never in the bronco. I'm sure I'll have some more axle wrap issues,but I can build a traction bar. Any other issues that anyones had with them on a bronco?
Old Jan 26, 2007 | 09:32 PM
bc56845's Avatar
bc56845
Also-I would run either an angled block or a shim for pinion angle
Old Jan 27, 2007 | 02:37 AM
RCrawler's Avatar
RCrawler
I would run either a lift spring or do a shackle flip. If you are planning on wheeling it, wheel hop will be a problem which will ultimately lead to breakage. Adding a traction bar will take away most of the flexibility that you will have be keeping the soft OE springs. It will only mask the problem of poor engineering.
Jason
