Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape electrical problem
Old Jan 26, 2007 | 07:00 PM
dehamma's Avatar
dehamma
In the past, these forums have been very helpful. There are some very knowledgeable and generous people ou there.
I have a 2002 Escape LTD 4WD 3.0 L. The other day I noticed that, first of all, When I opened the door to get in, there is no interior dome light (front or rear). Whn I start the vehicle, I noticed that the gauges all the way to one side, and then activate. The radio does not come on and the dash lights are in dim mode and are able to be turned brighter manually. Also, the headlight "turn off" delay, after I shut the vehicle off does not work. The lights just go off with the vehicle, even when the headlight switch is left on. I am thinking, a fuse, but regardless of what the owner's anual says, I can not locate the fuse panel to check them. Any advise or helpful thoughts are greatly appreciated.
Dehamma
