Sponsored by: Real Truck
calipers
Old Jan 26, 2007 | 05:35 PM
tietje_3's Avatar
tietje_3
calipers
Hey,
It look like my calipers are causing a vibration in my 2003 f350 (single rear V10).
I was wondering if the calipers from a 2005+ will fit my truck or if i have to buy calipers from a 199 to 2004
Old Jan 26, 2007 | 07:45 PM
boxcar1974's Avatar
boxcar1974
My guess is no for the reason is they are bigger to compensate for larger wheels on 05+ models. They will not fit behind a 16" wheel.
Old Jan 26, 2007 | 10:03 PM
dagren99's Avatar
dagren99
Caliper
Have you checked the caliper slide pins?
These frequently stick & create a vibration or 'hopping' in the front end.
DG
Old Jan 31, 2007 | 09:00 AM
tietje_3's Avatar
tietje_3
That’s a good idea I have not thought of checking those.
See I had a bad vibration so I turned the rotors and everything seems nice for a while say a month or 2 and not I have the vibration again. So I’m thinking it has something to do with the calipers, or am I way off
I'll have to check the guide pins and see if I can fix that
