Sound like a GEM problem?
Old Jan 26, 2007 | 04:15 PM
medicbearusaf's Avatar
medicbearusaf
Bought a 95 4x4 4.0 AT when purchased the wipers worked 4x4 worked dome light worked all blower settings worked.... Since then that was about 5 months ago one by one they went out... Well the middle 2 blower settings, 4x4 and dome went at the same time... Wipers worked fine then went wacky (woruld run when they wanted to, sprayed fluid only in a certain position would be on low run on high and vice versa would only turn off in middle intermittent) that last about a day and since then they havent run... I located a replacement GEM for it for 70$ does that sound like a feesible source of the problems... All fuses look good swapped around the relays with no luck, changed the wiper switch.... No luck,,,
Old Jan 26, 2007 | 08:09 PM
ReAX's Avatar
ReAX
Random electrical gremlins like that tipically mean the GEM is toast. It may require reprogramming, but it should fix you up.
Old Jan 27, 2007 | 12:46 PM
medicbearusaf
UPDATE
**UPDATE**
Well turns out when i replaced the switch a while ago the one i swapped it with wasnt doin anything.. So i put the original back in.... Well turns out somewhere i had a bad connection to the GEM... I wiggled it and boom got my 4x4 back. Dome light, door chime, and wipers went crazy swapped the replacment switch in.. PERFECT!!!!
My wiper pump was workin when they went crazy now its not so i dunno if if its gettin a bad connection in the switch itself now so im gonna open it up and clean it...
Old Jan 28, 2007 | 01:56 PM
Dave257's Avatar
Dave257
Good save, sometimes you have to think about it and try something different..
Dave
