pinion angle
Old Jan 26, 2007 | 02:48 PM
str8racing's Avatar
str8racing
pinion angle
i have a 1994 f150 that was lifted before i bought it. has 35" tires on it but i don't know the specs on the lift. i replaced the center driveshaft support but now makes grinding noise, is my pinion angle to much if so what can i do to fix it?
Old Jan 26, 2007 | 08:33 PM
ReAX's Avatar
ReAX
Shims are available that go between the axle perch and spring pack. If you have a single ujoint on each end the angles should be complentary, if you have a double on one end the angles should be equal.
