67 ford ranchero
Old Nov 6, 2000 | 08:23 AM
vwmeoww's Avatar
vwmeoww
67 ford ranchero
hi! i am new to this area of ford trucks and am excited as all hell to have purchased a 67 ranchero which appears to be all original please if you would be so kind and help me out with the engine tag identification the top row on the metal tag says 289 E 67 Bottom row says HE 239 -A 13 the original color is in doubt as well on the plate it says color is W is this Wimbledon white?? also the trans is listed as "I" and the axle is "A" interior trim is 4U please any information you can help me out with would be most appreciated Thanks!! total VIN NUMBER IS 7K48C162312
Old Nov 15, 2000 | 06:06 AM
DeenHylton's Avatar
DeenHylton
67 ford ranchero
Old Feb 11, 2001 | 06:44 AM
maverick70's Avatar
maverick70
67 ford ranchero
Your car was built at the Kansas City plant , your engine is a 200 hp 289 2 bbl. carb V8. Your axle ratio is a 3.00:1 and has a factory limited slip unit. If the "W" was listed under color and came off the plate where the VIN is listed, then it means your car came with Medium Aqua Metallic paint, you have a 3 spd. manual trans. with the 2.77 first gear ratio. Look for the body code on the metal tag for a 66A, 66B, or 66D and repost here and I will tell you which model Ranchero you have. I am unsure at this time what the 48 code means and the 4U interior, but when I find them, I will get back to you. Hope this helps.
maf226
Sep 28, 2017 10:48 AM
fredo181
General Automotive Discussion
19
Feb 4, 2016 04:39 PM
73 fourxfour
Mar 3, 2015 01:13 AM
frogjaw
Dec 21, 2012 03:20 PM
m4ximusprim3
Apr 16, 2012 01:28 PM
