g/p dilemma
Old Jan 25, 2007 | 09:01 PM
kg4yub's Avatar
kg4yub
g/p dilemma
been driving 86 f250 6.9 c6 for 15 yrs when first purchased it developed gp prob would not heat long enough.changed temp sensor, g/ps,and relay to no avail.so got a set of "gm slow glow" [12v olds] put constant duty relay and push button switch under dash under dash and counted for 1 minute. now that ive lost 1 or 2 gps [dosent hit on all 8 on start up] .my question is what sort of aftermarket system is available that i can go back to quick glow [6v] plugs that dosent require coolant sensors ect ? many thanks butch
Old Jan 25, 2007 | 09:20 PM
Dave Sponaugle's Avatar
Dave Sponaugle
kg4yub,
Welcome to FTE and the IDI diesel forum.
I have Motorcraft/Beru ZD9 glow plugs in my 6.9.
Push the button for 10 seconds and start the engine.
Old Jan 25, 2007 | 09:54 PM
kg4yub's Avatar
kg4yub
dave many thanks for prompt response i take it that the prob has been around for a long time. and your method only requires gp replacement no @#$&* controller again many thanks regards butch
Old Jan 26, 2007 | 03:26 PM
PLC7.3's Avatar
PLC7.3
Not sure if Dave is running a straight power system to the GPs, better double check with him.
Old Jan 26, 2007 | 07:30 PM
Dave Sponaugle
I am running a manual control system with push button, just like described in the original post.
The only thing different is 10 seconds on the button to start it instead of one minute.
