Engine Problems Please Help!!!!
Old Jan 25, 2007 | 08:17 PM
00bucker's Avatar
00bucker
I have a ford 1990 302 that has bad blowby. It has lost alot of power and seems to be giving up on me. I don't have a compression gauge, so i can't check my compresion. Is there any thing i can check other than that?? Again thanks for all your help!!!!
Old Jan 26, 2007 | 08:41 AM
ubereal2's Avatar
ubereal2
You're going to need some kind of tool. Either a compression, or vacume gauge. Either will get you some kind of an idea whats going on.
Bob
Old Jan 26, 2007 | 09:24 AM
00bucker's Avatar
00bucker
Thanks, Thats what i figured. I was hoping some one could tell me what might be wrong. The engine only has 60,000 Miles on it since it was rebuilt, and it was rebuilt good. Every thing was replace. It was bored .60 over and everything. It should have lasted longer i think. I do have a pretty bad rear main leak. Well thanks for everything
Old Jan 26, 2007 | 09:56 AM
Kemicalburns's Avatar
Kemicalburns
pull codes, www.fordfuelinjection.com has instructions using a paperclip and some time. you may have a clogged cat converter, bad fuel pump, clogged fuel filter, timing off etc..
are you running larger then stock tires? how many miles on the tranny?
Old Jan 26, 2007 | 10:14 AM
00bucker's Avatar
00bucker
I am not running big tires. They are the original size. My tranny is about to take a crap. Refer to post:https://www.ford-trucks.com/forums/5...lp-please.html
Old Jan 26, 2007 | 11:07 AM
Kemicalburns
well the tranny issue could be a factor
Old Jan 26, 2007 | 11:47 AM
00bucker's Avatar
00bucker
Thats kind of what i thought. But i have so much blowby. I have a full stream of of air coming out of my dip stick. Plus the air is realy smokey. Any thoughts??
Old Jan 26, 2007 | 11:57 AM
Kemicalburns
replace your pcv valve an tubing.
Old Jan 26, 2007 | 12:06 PM
00bucker's Avatar
00bucker
ok. il try that.
Old Jan 26, 2007 | 12:14 PM
00bucker's Avatar
00bucker
Thanks Kemicalburns
Old Jan 27, 2007 | 11:25 PM
fordberg's Avatar
fordberg
You say that you have a full stream of air coming out of the dipstick. High air pressures coming from the engine insides is a sign of bad rings or a hole in a piston. You will need to do a compression check
Old Jan 28, 2007 | 09:50 AM
baddad457's Avatar
baddad457
Your transmission could have too much line preessure in the torque converter, that will force the crankshaft forward and wear out the thrust bearing and eventually wear the counterweights against the main saddles. I've seen one 90's 5.0 from an AOD transmissioned van do this. I caught it in the nick of time.
Old Jan 28, 2007 | 08:16 PM
00bucker's Avatar
00bucker
Thanks. I will check the compression. That will tell the tell. But.... what about the trans?? what do i check for?? how do i know??
Old Jan 29, 2007 | 06:13 AM
baddad457's Avatar
baddad457
As for diagnosing the transmission, that I can't tell you, but if you pulled the engine, you'd see the results, if that's what was happening. See a transmission shop? Unless someone else here knows more about this and can guide you through it.
Old Jan 29, 2007 | 07:17 AM
HemiEater's Avatar
HemiEater
you could try this. Cylinder Contribution Test
if it's carb'ed it will be easier
if injected you'll need to disable the idle control
get a tachometer and set it up in the engine compartment
start and warm up the motor
get it to idle normal (wright donw the rpms)and start pulling plug wires at the cap one at a time
with one wire off take note of the rpm's (wright it down)
replace the wire and remove the next one, take note of the rpms
after you have done all 8 look at the readings, the one that has the less of an rpm drop will be the weakest cylinder.
give it a try works good........
