Lets see all of your lifted Excursions
#1531
The Xombie Stomper
2003 Ford Excursion 7.3 Turbo Diesel Limited
- 8” Skyjacker lift kit
- 37” BFG Baja TA tires
- TW double bead lock wheels
- BDS Fox 2.0 shocks
- Roadmaster Active Suspension (RAS) kit
- TGC / Bilstein dual steering damper
- Front steering stabilizer kit
- Tru-Cool Max Low-Pressure Drop Transmission Oil Cooler
- Power Stop severe-duty brake kit
- Bully Dog Triple Dog GT Diesel Gauge / Tuner (yeah yeah yeah, boooooo Bully Dog, but I like it)
- Banks 4” turbo back straight pipe free flow exhaust
- Motorcraft AIS Severe Duty Air Filter Kit + Zoodad mod
- 50” curved LED bar
- 20” bumper LED bar
- Mile Marker hub locks
- Pioneer head unit / Infinity 9 speaker system / Alpine digital amps
- Air horn
- LED bulb replacements throughout interior
- Custom headlamp housing with HID kit
- Air horn
#1532
Received 5,160 Likes
on
#1533
The Xombie Stomper
- Air horn
- Air horn
#1534
#1535
Stock gears bud. Truly I'm really impressed. All I lost was fuel economy. It's really pretty impressive the power I do have. Using my Supertuner I set it in performance mode. I can bark the rears from a dead stop when the conditions are perfect. (I.e. no a/c, fan, extreme power draw)
I was able to tow a 12k lb (weighed it before I hooked up) dump trailer like it was nothing. Remember the 6.8l power band is between 35 and 4500 rpm. I'm thinking of adding a supercharger and mid to med cams next.
Which one of the stock gears, there were two. . I'm assuming from your report that your rig has the 4.30 gears if its still fun to drive with the 37"s.
#1537
#1538
#1539
boy i really like some of these lifts. mine is still stock height with some 33's on it but i am wanting to go higher. i originally wanted to do a 6 inch lift with 37's but after seeing some of the bigger ones i kinda want to go bigger. i have a good idea how big mine would be with a six inch lift and 37's because at one time i owned an 04 f350 with a 6 inch lift and 37's. i was wondering if any of you kind gentlemen or ladies with the 8 inch skyjacker or bds lifts or the 10 inch bds lift would be so kind as to post a picture or pictures of you excursion with you or someone or something standing beside it so i could get a height reference as to how big it would be. i am 5'8 and my wife is 5'4. i didn't want to go to big and i also have a boat to tow. my excursion is a 2000 limited with the 7.3 and 4x4. thank you for any help or pictures posted
#1541
#1542
#1543
#1544
#1545
Just got mine back with Xs and Mod-Cs. Also had adjustable track bar, Bilsteins, Hellwig rear bar, and all poly bushings. I am still rolling on the stock rubber but new shoes are next. I also installed all the LEDs and HIDs myself and it was worth every cent and a snap install.
Looking good Jay! Nice lift and a very clean rig with a great shine!
How big of a tire are you planning? And what gears does your V-10 EX have?
Remember that taller tires will reduce the effective ratio and rob you of performance, it will be even more obvious if you tow at all. I you do tow heavy it may be time to consider new deeper gears to go with the soon to be bigger rubber.
